Buy Suunto Ocean or EON Core - Save 50% on Tank Pod. Shop now!
Suunto Race User Guide
Widgets
Widgets give you useful information of your activity and training. The widgets are accessible from the watch face by swiping up or turning the crown.
It is possible to pin a widget for quick and easy access. From watch face, press the crown and double tap the screen to select which widget you want to have pinned. It is also possible to pin a widget under Customize in the Control panel.
The widgets can be turned on/off from the Control panel under Customize > Widgets. Select which widgets you want to use by turning the toggle on.
Widgets Toggles
You can also select which widgets you want to use in your watch and in which order by turning them on and off and sorting them in Suunto app.
