Mother's Day: Discover our selection
Sign up for the newsletter and get 10% off | Free returns
Check out the top 3 reasons to own a dive computer, and find out how to choose the right Suunto dive computer for you based on your needs and wishes.
The Suunto DM5 allows you to download your dive logs for advanced analysis and create dive plans. Transfer dive logs from your compatible Suunto dive computer, upload dive plans, and customize your dive computer.
Learn the essential features of Suunto D4i, Zoop Novo, Vyper Novo: set up your diving modes (air and nitrox), pair the computer with a transmitter (D4i and Vyper Novo) and access the memory logbook. Or just make virtual dives!
Measurements | 71,2 x 71,2 x 29,5 mm / 2,8 x 2,8 x 1,16 " |
Weight | 134 g / 4,73 oz |
Bezel material: | Composite |
Glass material: | Acrylic |
Case material: | Composite |
Strap material: | Elastomer |
What's in the box? | Suunto Vyper Novo White, boot, bungee adapter, bungee (1 meter), USB cable, display shield, warranty leaflet, safety leaflet, quick guide and Suunto logo sticker |
Country of manufacture | FI |
In time mode | 2 years |
Water resistance | 80 m (ISO 6425, EN 13319) |
Battery life 100 dives/year | 1.5 years |
Battery type | CR 2450 |
User replaceable battery | |
Time, date | |
Alarm clock | 1 daily alarm |
Dual time | |
Stopwatch timer | |
Languages | EN |
Backlight | electro-luminescent & phosphor-luminescent |
Configurable backlight | duration: off, 5, 10, 20, 30, 60 s |
Display type | matrix |
Display resolution | 49 x 22 |
Battery indicator | low battery indicator |
Metric and imperial units |
Data transfer | USB cable |
Connectivity (between devices) | inductive |
Compatible with DM5 |
Digital compass | |
Tilt compensation | up to 45° |
Declination correction | |
Direction scale | degrees |
Needle | compass rose |
Globally balanced | |
Bearing lock with direction indicator | |
Compass accuracy | 5° |
Compass resolution | 1° |
Operating temperature | 0° C to +40° C / +32° F to +104° F |
Storage temperature | -20 ° C to +50 ° C / -4° F to +122° F |
Maximum operating depth (EN 13319) | 80 m |
Nitrox (and air) | |
Freedive | |
Gauge | |
Dive time | 0 to 999 min |
Surface time | 0 to 99 h 59 min |
No fly time | |
Safety Stop | |
Deep Stop | |
Ascent time display | 0 - 199 min (- - after 199) |
CNS/OTU (OLF) calculation | |
Wireless air integration | optional |
Gas time | |
Decompression model | Suunto RGBM |
Personal adjustment | 0 - 2 |
Altitude adjustment | 0 - 300 m / 300 -1500 m / 1500 - 3000 m |
Gases | up to 3 gases (Oxygen 21 - 99%) |
Gas max pO2 | 1.2 - 1.6 |
Gas switching | |
Timer | |
No-decompression planner | |
Logbook memory | ~140 h (20 s sampling rate) |
Logbook bookmarks | |
Logbook sampling rates | 10, 20, 30, 60 s (1, 2, 5 s freediving) |
Dive history | lifetime |
Dive time | |
Maximum depth | |
Tank pressure | |
Gas time | |
High pO2 (hyperoxic) | |
Too fast ascent | |
Decompression ceiling violation | |
Deepstop violation | |
CNS/OTU (OLF) 80% / 100% | |
Switch gas (better gas is available) |
Apnea timer (O2/CO2 tables) | |
Freedive number | |
Freedive day history | |
Freedive total history | lifetime |
Depth notify | yes (5) |
Surface time notify |
Temperature display range | -20° C to +50° C (+/- 2° C) / -9° C to +122° F (+/- 3.6° F) |
Temperature | |
Temperature resolution | 1° C / 1.5° F |
Chrono |
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto dive computer.
Your country or region:
United States
