Summer Sale: Up to 20% off on selected products! Discover
Strap Deals: 50% off on selected products! Discover
Suunto Ocean User Guide
Touch screen and buttons
Suunto Ocean has a touch screen and three buttons you can use to navigate through displays and features.
Swipe and tap
  • swipe up or down to move in displays and menus
  • swipe right and left to move backwards and forwards in displays
  • tap to select an item
Upper button
  • from watch face, press to open the list of the most recently used sport modes
  • from watch face, long press to define and open shortcuts
Middle button
  • press to select an item
  • from watch face, press to open the pinned widget
  • from watch face, long press to open settings menu
  • keep pressed to go back in settings menu
Lower button
  • press to move down in views and menus
  • from watch face, press to open the list of the widgets
While recording an exercise:
Upper button
  • press to pause the activity
  • long press to change activity
Middle button
  • press to change displays
  • long press to go back to the previous display
Lower button
  • press to mark a lap
  • long press to open the control panel where you find the exercise options
  • when the activity is paused, press to end or discard the activity
While freediving and scuba diving:
Upper button
  • press to open the options menu (freediving)
  • press to access the list of available gases (Multigas mode only)
  • long press to change brightness
Middle button
  • press to change displays (freediving)
  • press to change arch (scuba diving)
Lower button
  • press to change the switch window item
  • long press to lock and unlock buttons
The touch screen is inactive when it is in contact with water. This means that underwater you have to use the buttons to navigate through displays.
