Suunto Wing User Guide
Getting started
Buttons
Suunto Wing has three buttons you can use to switch song, adjust volume and answer or end phone calls.
buttons wing
  1. multifunction button
  2. + and power button
  3. button
Switching on/off the device
  • keep the + button pressed for 3 seconds to switch the device on or off
Listening to audio
  • press the multifunction button once to start or stop playing the audio
  • press the multifunction button twice to skip to the next track
  • press the multifunction button three times to return to the previous track
  • press the + button to increase volume
  • press the button to decrease volume
  • keep the multifunction button and the + button pressed simultaneously for 3 seconds to switch sound mode
Making a phone call
  • press the multifunction button once to answer or end a call
Adjusting settings when the device is on
  • keep the button pressed for 3 seconds to switch the LED lights on
  • keep the button pressed again for 3 seconds to switch between different light modes
  • keep the multifunction button and the button pressed simultaneously for 3 seconds to enable Head Movement Control
  • keep the + and buttons pressed simultaneously for 3 seconds to enter pairing mode
  • in pairing mode, keep the multifunction button and the + button pressed simultaneously for 3 seconds to enable dual device connection
