Suunto Ocean User Guide
Battery power management
Your Suunto Ocean has a battery power management system that uses intelligent battery technology to help ensure your watch does not run out of power when you need it most.
Before you start recording an exercise (see Recording an exercise) you see an estimate of how much battery life you have left in the current battery mode.
Exercise Start 02 S9PP
There are four predefined battery modes; Performance (default), Endurance, Ultra and Tour. Changing between these modes will change the lifetime of the battery but also changes the performance of the watch.
By default, Tour mode disables all HR tracking (both wrist and chest).
While in the start display, scroll down and select Battery mode to change battery modes and see how each mode affects the performance of the watch.
Battery Modes S9PP
Battery saving settings do not affect dive activities.
Battery notifications
In addition to the battery modes, your watch uses smart reminders to help you ensure you have enough battery life for your next adventure. Some reminders are preemptive based on, for example, your activity history. You also get notified, for example, when the watch notices you are running low on battery while recording an activity. It will automatically suggest changing to a different battery mode.
Your watch will alert you once when the battery is at 20% and again at 10%.
Battery Warning S9PP
While diving, your watch will alert you once when the battery is at 10% and again at 5%.
alarm battery
WARNING:
Suunto recommends you do not dive with a battery lower than 10%.
CAUTION:
Only use the provided charging cable when charging your Suunto Ocean.
Indice
