Suunto Wing User Guide
LED lights
LED lights are designed to enhance your visibility during sports activities in darker conditions. Thanks to the red LED lights on the sides of your Suunto Wing, your surroundings can notice you more easily.
You can turn the LED lights on or off and you can select from different light modes: static lights or blinking with different intervals. Turn the LED lights on or off and switch light modes in the Suunto app or by long pressing the button.
WARNING:
The LED lights do not replace any professional protective or rescue equipment. Always make sure that you use the appropriate safety gear for your specific activity.
WARNING:
The visibility range of the LED lights may be affected by various factors, including weather conditions, ambient brightness, air quality, and other external factors. Always consider these factors before using your headphones.
The LED lights accelerate the battery consumption of the headphones, and when turned on, they reduce the battery life by about 50%.
LED lights have a protective coating that protects the lights during production. Please note that this coating will wear off the product over time. This phenomenon is normal and it does not cause any quality change.
Indice
