Suunto Race 2 User Guide
- Automatic display brightness
The display has three features that you can adjust: the level of brightness (Brightness), whether the inactive display shows any information (Always-on display), and whether the display activates when you raise and turn your wrist (Raise to wake).
The display features can be adjusted from the settings under General > Display.
The Brightness setting determines the overall intensity of display brightness; Low, Medium or High.
The Always-on display setting determines if the inactive display is blank or shows information, for example, the time. Always-on display can be toggled to on or off:
- On: The display shows certain information all the time.
- Off: When the display is inactive, the screen is blank.
The Raise to wake feature activates the display when raising your wrist to look at the watch. The three options for Raise to wake are:
- Off: Raising your wrist does nothing.
- Display only: Raising your wrist only activates the display. A button press is required to use the watch.
- Full wake mode: Raising your wrist activates the watch, making it ready to use.
Prolonged use of the high brightness display reduces battery life and may cause screen burn-in. Avoid using high brightness for extended period to lengthen display lifetime.
